Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3788 Cmd Rej: OPC, CICS, CICE are required if SI is 4, 5 or 13
If a value of 4, 5, or 13 (or tup, isup, or qbicc, respectively) is specified for the si parameter, then the opc, cics, and cice parameters must be specified.
Recovery
  1. Display the current settings for the si parameter. Enter the rtrv-appl-rtkey command.
  2. Re-enter the ent/chg/dlt-appl-rtkey command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
