Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4000 Cmd Rej: No data is available to display.
Audit data is available only if the execution of a periodic or manual DDB audit is complete.
Recovery
Use the aud-data command to start a manual DDB audit or wait for periodic DDB audit start. Refer to the command description in Commands User's Guide for more information.
Re-enter the rept-stat-ddb command that generated this error message.
If this error message appears again, contact My Oracle Support. See My Oracle Support (MOS).
