Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4035 Cmd Rej: TTA must be specified for a direction of ATOI
If the dir=atoi parameter is specified, then the tta parameter must be specified.
Recovery
Re-enter the chg-gtcnv command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
