Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4530 Cmd Rej: MAPSET must be specified if action is FORWARD/DUP/DUPDISC
If a value of forward, duplicate, or dupdisc is specified for the (n)dfltact parameter, then the (n)mapset parameter must be specified.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
