Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4575 Cmd Rej: Replace and Append Point Code lists are mutually exclusive
The rpcl parameter and apcl parameters cannot be specified together in the command.
Recovery
Re-enter the chg-loopset command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
