| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The force parameter can be specified with only the appl, data, or initclk parameter.
Recovery
Re-enter the init-card command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
