Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3169 Cmd Rej: No change required for this timer and L2tset
Timers are not allowed to change for a level 2 timer set (l2tset parameter) value greater than 35.
Recovery
  1. Re-enter the chg-l2t command with an l2tset value in the range 1-35 to change the nodata, t2, or t7 timers.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
