Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2358 Cmd Rej: Routeset is empty
If the all=yes parameter is specified, then at least one route must be assigned to the routeset.
Recovery
  1. Display the routes in the database. Enter the rtrv-dstn command.
  2. Re-enter the dlt-rte command specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - SS7 User's Guide and Database Administration - IP7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
