Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4359 Cmd Rej: For SUBNETNUM specified the prefix is not provisioned
A prefix with the same prefix number as the value specified for the subnetnum parameter must already be provisioned for the ISUP NP with EPAP feature.
Recovery
  1. Display the entries in the FEATPFX table. Enter the rtrv-prefix command.
  2. Provision a prefix for the ISUP NP with EPAP feature as necessary. Refer to the command description for the chg-prefix command in the Commands User's Guide for assistance.
  3. Re-enter the ent-subnetid command that generated this message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
