Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4819 Cmd Rej: Failure reading TSTMSG Table
The TSTMSG table is corrupt or cannot be found.
Recovery
Re-enter the command that generated this error message.
Contact My Oracle Support if this mes
