| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
For the act-upgrade command, the value specified for the action parameter must correspond to the upgrade phase of the system.
Caution:
It is strongly recommended that this command be used only in conjunction with the system Upgrade Procedure for the target release. The Upgrade Procedure provides step-by-step information on performing an upgrade.For the act-flash command, the card must be running an inactive GPL.
For the init-flash command the card cannot be running an inactive flash GPL.
Recovery - act-upgrade
act-upgrade:action=dbstatus command.The phase of the upgrade process is shown in the header of the command output.
act-upgrade command that generated this error message, specifying an action that corresponds to the upgrade phase. Refer to the command description in Commands User's Guide for a list of upgrade phases. Recovery - act-flash
rept-stat-gpl command. A plus sign (+) in the column between the RUNNING and APPROVED columns indicates an inactive GPL.
act-flash command that generated this error message. Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
Recovery - init-flash
