| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
For the chg-npp-as command, if less than 8 Service Actions are provisioned, then only a value of none can be specified for the sa8val parameter.
For the ent-npp-as command, if less than 8 Service Actions are provisioned, then the sa8val parameter cannot be specified.
Recovery
