Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2869 Cmd Rej: NCAI param is only valid if both feat CRMD and NCR are ON
The Cluster Routing and Management Diversity (CRMD) and Nested Cluster Routing (NCR) features must be turned on before the ncai parameter can be specified.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.
Recovery
  1. Display the status of the CRMD and NCR features. Enter the rtrv-feat command.
  2. Turn on the CRMD and NCR features if necessary. Refer to the Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance
  3. Re-enter the command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
