| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The group codes for the DPC(s) and APC/SAPC must match if the multgc=no parameter is specified.
The multgc=no parameter can be specified only if there are no routes with group codes different than the ADJPC's group code.
If the ADJPC's group code is changed, then the multgc=yes parameter must be specified or there must be no routes using the linkset.
Recovery
