Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5191 Cmd Rej: Password has too many character matches with old password
The password must contain fewer duplicate characters from the existing password than the number specified by the pchreuse parameter in the chg-secu-dflt command.
Recovery - login command
Re-enter the password, specifying a value with fewer duplicate characters from the existing password.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS) for assistance.
Recovery - chg-pid command
  1. Display the system security defaults. Enter the rtrv-secu-dflt command.
  2. If desired, use the chg-secu-dflt command to change the system security defaults.
  3. Re-enter the chg-pid command that generated this error message. When prompted, specify a password that matches the requirements in the rtrv-secu-dflt command. Refer to the command description in Commands User's Guide and to the Database Administration - System Management User's Guide for assistance.
