Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Contents
Previous
Next
E2907 Cmd Rej: No active LFS Test on the specified link
There is no active LFS Test on the specified link.
Recovery
Display the status of the currently active LFS tests. Enter the
rept-stat-lfs
command.
Re-enter the
dact-lbp
command that generated this error message, specifying a link with an active LFS test.
Contact My Oracle Support if this error message appears again. See
My Oracle Support (MOS)
