Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2006 Cmd Rej: Missing parameter block separator
Use a colon (:) to separate multiple blocks.
Recovery
Re-enter the command that generated this error message, specifying a colon (:) between the input values. Refer to the command description in Commands User's Guide for assistance.
