E2350 Cmd Rej: At most two linksets can be assigned same cost
The 6-Way Loadsharing on Routesets feature must be turned on before more than 2 routes can be provisioned with the same relative cost.
Recovery
Display the routes and their cost values. Enter the rtrv-rte command.
Display the status of the 6-Way Loadsharing on Routesets feature. Enter the rtrv-ctrl-feat command.
If the feature does not appear in the output, then the feature is not enabled. if the feature has a status of OFF, then the feature is enabled but is not turned on.
Enable and turn on the 6-Way Loadsharing on Routesets feature as necessary. Refer to the Database Administration - SS7 User's Guide for assistance.
Re-enter the ent/chg-rte command that generated this error message.
