Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4810 Cmd Rej: All links must be OOS-MT-DISABLED to modify RCONTEXT
All links must be in the OOS state before the rcontext parameter can be specified.
Recovery
  1. Display the linkset. Enter the rept-stat-ls command.
  2. Change the link state as necessary. Refer to the Database Administration - IP7 User's Guide for assistance.
  3. Re-enter the chg-ls command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
