Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4381 Cmd Rej: CIC Range overlaps an existing range
The range specified by the cic and ecic parameters cannot overlap an existing CIC range.
Recovery
  1. Display the existing exception route entries. Enter the rtrv-rtx command.
  2. Re-enter the ent-rtx command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
