Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2508 Cmd Rej: SCMGFID is invalid
If the ssn=1 parameter is specified, then the scmgfid parameter must be specified.
If the ssn parameter has a value other than 1, then the scmgfid parameter cannot be specified.
Recovery
Re-enter the ent/chg/dlt/rtrv-cdpa command, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GWS User's Guide for assistance.
