Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2328 Cmd Rej: CLLI not defined in route table
The value specified for the clli parameter must already be defined in the Route table.
Recovery
  1. Display the existing CLLI values. Enter the rtrv-rte command.
  2. Configure a new CLLI value if necessary. Refer to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
