Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3479 Cmd Rej: Port Check for MO SMS feature must be enabled
The Portability Check for MO SMS feature must be enabled before an Action Set containing the FRAUDCHK Service Action can be specified as a value for the asn parameter with the MOSMSGCGPN service.
Recovery
  1. Display the status of the Portability Check for MO SMS feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Enable and turn on the feature as necessary. Refer to the MO SMS User's Guide for assistance.
  3. Re-enter the ent/chg-npp-srs command that generated the error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
