Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2858 Cmd Rej: EE Filter associated to Network Card
The specified filter should not be associated with any network card.
Recovery
  1. Use the rtrv-ee-card command to see the cards with which the filter is attached.
  2. Use the chg-ee-card command to detach the filter from each associated card.
  3. Re-enter the dlt-ee-flt command to delete the filter.
    Refer to the command descriptions in Commands User's Guide for assistance. Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
