Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2337 Cmd Rej: If GWSA=OFF then GWSD must also be OFF
The gwsd=on parameter can be specified only if the gwsa=on parameter is specified. If the gwsd=on parameter is specified, then the gwsa=on parameter must be specified.
Recovery
Re-enter the ent/chg-ls command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - SS7 User's Guide (for SS7 linksets) or the Database Administration - IP7 User's Guide (for IP linksets) for assistance.
