Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5354 Cmd Rej: SA2VAL requires SA2 to be provisioned
For the chg-npp-as command, if less than 2 Service Actions are provisioned, then only a value of none can be specified for the sa2val parameter.
For the ent-npp-as command, if less than 2 Service Actions are provisioned, then the sa2val parameter cannot be specified.
Recovery
  1. Display the existing Service Actions in the Action Set. Enter the rtrv-npp-as:mode=full command.
  2. Provision Service Actions as necessary. Refer to the Numbering Plan Processor (NPP) User's Guide and to the appropriate feature manual for assistance.
  3. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
