| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
For the ent-scr-blkdpc command, when a blocked DPC screen is created, the first entry for the ni-nc-ncm, zone-area-id, or msa-ssa-sp must be c-c-c or the npc=c parameter must be specified.
For the ent-scr-blkopc command, when a blocked OPC screen is created, the first entry for the ni-nc-ncm, zone-area-id, or msa-ssa-sp must be c-c-c or the npc=c parameter must be specified.
For both commands, subsequent entries can be specific point codes.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - GWS User's Guide for assistance.
Contact My Oracle Support for assistance if this error message appears again. See My Oracle Support (MOS).
