Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2856 Cmd Rej: ELEI is only valid if the CRMD feature is ON
The Cluster Routing and Management Diversity (CRMD) feature must be turned on before the elei parameter can be specified.
Once a feature that is controlled using a feature bit has been turned on, it cannot be turned off.
Recovery
  1. Display the status of the CRMD feature. Enter the rtrv-feat command.
  2. Turn on the CRMD feature if necessary. Refer to the Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance
  3. Re-enter the command that generated the error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
