Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5135 Cmd Rej: Primary remote hostname required before alternate
The rhosttype=primary parameter must be specified before the rhosttype=alternate parameter can be specified.
Recovery
Re-enter the chg-assoc command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
