Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2485 Cmd Rej: All entered point code elements must be C if any are C
If one of the point code parameters has a value of c (for “Continue”) then all of the point code parameters must have a value of c.
If c is specified for the first parameter, then the other parameters will default to c in the database.
Recovery
Re-enter the command, that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - GWS User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
