| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
A valid number of digits must be entered for the parameter values. The values represented by <min> and <max> specify the valid minimum and maximum number of digits allowed for the command parameter.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
