Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4775 Cmd Rej: MNP CRP Feature must be ON
The MNP Circular Route Prevention (CRP) feature must be turned on before the crptt parameter can be specified.
Recovery
  1. Display the status of the MNP CRP feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled, but is not turned on.
  2. Enable the feature as necessary. Refer to the G-Port User's Guide for assistance.
  3. Re-enter the chg-gsmopts command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
