Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3363 Cmd Rej: Feature cannot be enabled with DSM less than 4G is present
The feature cannot be enabled because a DSM card with less than 4 gigabytes of memory is present in the system.
Recovery
  1. Display the part numbers for each DSM card. Enter the rtrv-bip command.
    Part Numbers 870-1984-05,-06,-07,-11,-12,-13, and -16 indicate DSM 4G cards.
  2. Upgrade the hardware configuration as necessary.
    Refer to the Maintenance Guide for assistance.
  3. Re-enter the enable-ctrl-feat command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
