Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4128 Cmd Rej: SAPC entry present for the linkset
A secondary adjacent point code cannot already be provisioned for the linkset.
Recovery
  1. Display the linkset information. Enter the rtrv-ls:lsn command.
  2. Revise the settings as desired. Refer to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the chg-ls command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
