Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2391 Cmd Rej: Echo not allowed for telnet terminals
The value specified for the trm parameter cannot indicate a telnet port.
Recovery
  1. Display the terminals in the system. Enter the rtrv-trm command.
    They type of terminal is shown in the TYPE column.
  2. Re-enter the act-echo command the generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - System Management User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
