| Oracle® Communications EAGLE Commands Error Recovery Reference Release 46.6 E93312 Revision 1 |
![]() Previous |
![]() Next |
The appl parameter can be specified only with the period=last or period=specific parameter.
Recovery
Re-enter the rept-meas command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Measurements Reference for assistance.
