Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5112 Cmd Rej: GTT Action Set is referenced by translations
If the Action Set is referenced by a translation entry, then the Action Set cannot be deleted.
Recovery
  1. Determine whether the Action Set is referenced by a translation entry. Enter the rtrv-gta command.
  2. Remove the association between the Action Set and the translation entry. Refer to the Database Administration - GTT User's Guide for assistance.
  3. Re-enter the dlt-gttaset command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
