Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5266 Cmd Rej: LOCREQ response feature must be enabled
The LOCREQ Query Response feature must be enabled before the dftlrn parameter can be specified.
Recovery
  1. Display the status of the LOCREQ Query Response feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Enable the feature as necessary. Refer to the IS41 GSM Migration User's Guide for assistance.
  3. Re-enter the chg-is41opts command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the IS41 GSM Migration User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
