Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4733 Cmd Rej: Exception route does not support proxy destinations
If a proxy destination is used, then the ent-rtx command cannot be entered.
Recovery
  1. Display the proxy destination. Enter the rtrv-dstn:prx=yes command.
  2. Revise the data as necessary. Refer to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the ent-rtx command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - SS7 User's Guide for assistance.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
