Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3585 Cmd Rej: Dest IP Address is invalid
A valid destination IPv4 or IPv6 address must be specified as the value for the dest or dest6 parameter. Refer to the command description in Commands User's Guide for the criteria for a valid destination IP address.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in the Commands User's Guide and to the Database Administration - IP7 User's Guide for assistance.
