Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4842 Cmd Rej: Cannot set DefCC to NONE, if IDPR ON or IAR Base ENABLED
If the IDPR feature is turned on or the IAR Base feature is enabled, then the defcc=none parameter cannot be specified.
Recovery
  1. Display the status of the controlled features in the system. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
    The IDPR feature cannot be turned off after it has been turned on, and the IAR Base feature cannot be disabled if it is enabled. Contact My Oracle Support for additional assistance. See My Oracle Support (MOS).
