Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3455 Cmd Rej: SCTP Association or SLK provisioned: Card supports 16 links
All available links on the specified IPLIM card have already been provisioned.
Recovery
  1. Display the existing links. Enter the rtrv-slk command.
  2. Delete links as desired. Refer to the Database Administration - IP7 User's Guide for assistance.
  3. Re-enter the ent-slk command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
