Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4283 Cmd Rej: Command cannot be executed on a Telnet terminal
The specified command cannot be issued from a Telnet terminal (terminal IDs 17 to 40).
Recovery
  1. Display the terminal type. Enter the rtrv-trm command.
    The terminal type is displayed in the TYPE column.
  2. Re-configure the terminal type if desired. Refer to the Database Administration - System Management User's Guide for assistance.
  3. Re-enter the command that generated this error message from a valid terminal.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
