Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5398 Cmd Rej: Max no of unique EPCs/RealPCs cannot exceed 250
A total of 250 unique emulated point code and real point code values are supported in the PCT table.
Recovery
  1. Display the existing entries in the PCT table. Enter the rtrv-pct command.
  2. Delete or revise PCT entries as necessary. Refer to the Database Administration - SS7 User's Guide for assistance.
  3. Re-enter the ent-pct command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
