Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2886 Cmd Rej: DSTN address must be a full, network or cluster PC
The destination address must be a full point code, a network destination, or a cluster point code.
Recovery
  1. Display the destination point codes. Enter the rtrv-dstn command.
  2. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance with the command and to the Database Administration - SS7 User's Guide for assistance with destination point codes.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
