Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4519 Cmd Rej: CdPA GTT Set type must be cdgta
The GTT Set specified by the cdgtasn or gttsn parameter must have a set type of cdgta.
Recovery
  1. Display the set types. Enter the rtrv-gttset command.
  2. Change the set type if necessary. Refer to the Database Administration - GTT User's Guide for assistance.
  3. Re-enter the ent/chg/rtrv-gttsel command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
