Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E5326 Cmd Rej: TIF Range CgPN Blacklist feature must be enabled
The TIF Range CgPN Blacklist feature must be enabled before:
  • an Action Set containing the NOCGPNRLS Service Action can be specified as a value for the asn parameter and a value of tif, tif2, or tif3 can specified for the srvn parameter
  • an Action Set containing the FPFXRLS Service Action can be specified as a value for the asn parameter and a value of tifcgpn, tifcgnp2, or tifcgpn3 can specified for the srvn parameter
Recovery
  1. Display the status of the TIF Range CgPN Blacklist feature. Enter the rtrv-ctrl-feat command.
    If the feature does not appear in the output, then the feature is not enabled. If the feature has a status of OFF, then the feature is enabled but is not turned on.
  2. Enable the feature as necessary. Refer to the TIF User's Guide for assistance.
  3. Re-enter the ent/chg-npp-srs command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
