Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4079 Cmd Rej: Specified AS name not found
The value specified for the asname parameter must already exist in the AS table.
Recovery
  1. Display the entries in the AS table. Enter the rtrv-as command.
  2. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
