Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4883 Cmd Rej: Rule contains unsupported Service Actions
The NPP Rule contains a Service Action that is not supported by the NPP Service.
Recovery
Determine the Service Actions supported by the NPP Service. Refer to Numbering Plan Processor (NPP) User's Guide and to the appropriate feature manual for assistance.
Re-enter the ent/chg-npp-srs command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
