Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4804 Cmd Rej: ANAME is prohibited for a non-IPSG link
The aname parameter can be specified only for IPSG links.
Recovery
  1. Display the linkset. Enter the rtrv-ls:lsn= command.
  2. Re-enter the ent-slk command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide, to the Database Administration - SS7 User's Guide (SS7 links) and to the Database Administration - IP7 User's Guide (IP links) for assistance.
